Q9650 on i975X?
stonedwaldo420
I have a Dell Precision 390 at work with an i975X mobo and a Q6600 processor.
I would like to swap out the processor for a Q9650 and the Dell techs claim that it will work, and at worst, the Q9650 will run with a 1066FSB instead of 1333.
So, will an i975X support a Q9650?
Intel's website claims that it will support all Core 2 Extreme processors.... although they might mean only the ones with a 1066fsb.
I can't get a new computer for a year, but they will let me upgrade whatever i want on the existing system. What would be the fastest processor supported on this system? If i got an unlocked processor, could i adjust the multiplier?
I would confirm the board support 45nm chips which the q9650 falls into additionally confirm the bios has the correct microcode ( actually understands the cpu you are putting in ). Otherwise you should be ok the temps should be within the same range both were rated at 95w and vid ranges are also almost the same.
