I've got a brand spanking new Q9650.
I'm running an ASUS Rampage Formula X48 mainboard, with some reasonable good Corsair Ram (DDR2 1066). Cooling with a Zalman 7700CU cooler.
So far I've made 3.8 GHz @ 1.25v, with no other major adjustments. The voltage was just a stab in the dark as the CPU has a very wide voltage range and the Mobo has an even wider one. Load Line Calibration is enabled, so I have a very stable CPU voltage. Prime95 stable puts me right around 70C. The tower has ~120 CFM of air flow. I have not pushed further yet, but will do so as I get time (I'm working 120 Hours a week right now). I was hoping to get to 4GHz+ territory, and I'm looking for some advice on voltages, freqs and temps.
I know that the HSF should probably be upgraded, I'll be getting a Thermalright TRUE eventually.
Water cooling is NOT an option.
Other details about the rig are in the sig.
