Got my Q9650 installed yesterday, unfortunately while swapping it in I busted a peg on my Scythe Infinity heatsink so I'm on the stock Intel heatsink
. I may just leave it, not sure, I did put AS5 on it and it's running @ 37C idle and I have it overclocked to 3.6Ghz. It gets up to 55C load. Are those temps good?
Another thing that happened was my BIOS was set to Auto on the vCore and I had the thing running for a couple hours before it shut off. Checked and found it was overheating, running 95C idle lol! Installed Speedfan and noticed the vcore was set to 1.55! Turned it down to 1.2 (not sure what the default is) and that brought it down to it's current 37C idle temp and is now working well, hopefully that didn't hurt anything but glad I caught that rather quickly, not sure why the BIOS auto setting did that lol. Anyway, I'd like to try 4Ghz, you think I can do that with the stock heatsink? What settings should I set my FSB and vcore to try this?
I also dunno if I should just keep the stock heatsink as it seems to be doing OK I think, if not I dunno if I could fix the broken peg somehow on the Scythe or if I should look into some new heatsink. Suggestions?
