Q9550 multiplier at 8.....?
jime
I thought that this CPU had a multiplier of 8.5 but mine is reading 8.
Anyone have a clue on how to change this?
MB:Abit IP35-e
BIOS:18
CPU:Intel Q9550 E0 Stepping
Memory:Kingston HyperX 1066 (5 5 5 15) 2.20v
Any more info needed just let me know and I'll provide it.
Thanks for any replies.
jime
Confirming the CPU is on the officially supported CPU list from BIOS 13. This post on AnAndTech has someone with the multi at 8.5, so the board must be capable of doing it. Now, I thought this CPU had a locked multiplier, but this thread seems to suggest it's not locked. Silly question, but does the BIOS offer any adjustability?
I've been looking for a way to change it in the BIOS but as of yet haven't seen anything to allow this.
I don't see anything in the BIOS referring to the speedstep.
there has to be some cpu features that slow down the cpu when the cpu is not being used, you need to disable those features in the bios and it should read 8.5
What software are you using to read the multiplier? If it's showing 8.0, it's probably not Speedstep that is the problem. Grab the latest version of CPU-Z 1.50 if you haven't already.
I was using CPU-z 1.49, I d'led the newer version(1.50) and it also show 8.0. Also ran Everst and it also reads 8.0.
In my BIOS I turned-off the C1E function but no change. I don't see anything in the BIOS to change to 8.5.
I'm pretty much a noob but I'm not that nooby;) and I can't see anything in my BIOS in regards to this.:(:confused:
Once you're in the bios, go into the SoftMenu Setup. You should be able to change the multiplier there after setting the CPU Operating Speed to User Defined.
Nope,no luck. Went into SoftMenu and changed FSB to 400 which gave me the 3.2ghz
Didn't see anything in referrence to the multiplier.
Edit: I just saw a picture of a BIOS from someone working on this MB and it shows the multiplier option in the BIOS under SoftMenu. I do not have this in mine. ??????:confused:
A follow-up: I was able to get the correct multiplier by swapping out the M630A_18.Bin file located in the latest Bios(18) from Abit with a Bin file from the Hexus website. It's an update for E0 stepping. The file is named M630A.Bin. I had to re-name it to M630A_18 for it to work but it worked like a charm. I now have the multiplier function in my BIOS which was missing from the other BIOS Update.
It's good to know that the latest CPU with E0 stepping works on my Abit IP35-e because I love this board. It may be outdated but it kicks. I pushed it up to FSB/450 which ran this CPU at 3.825 with no problem whatsoever. A little voltage increase was all that was needed to run at this speed.
One happy camper.:)
