q9450 temps pic attached..seems weird
Putz
I have a custom title
Or is it normal to have different temps across the cores that vary alot?
i guess media player is running and probably using the first core as most stuff would until it needs to get the 2nd one loaded up
im going to be putting a thermalright 120 extreme on here tomorrow , right now im just using my old freezer 7 pro
its a Q9450 @ 3.6 1.28V only setting i had to change and its stable
Motherboard is an Asus maximus II
http://img75.imageshack.us/img75/3733/capturemu1.jpg
Fairly common to have differing temps across cores, yes. Even with lapping both the HS and IHS mine has one core that is just way lower than the other three. Like 7-9C lower. The low one is the same one as yours, actually.
weird noticed your running your cpu at 1.19v, might have to see if i can get mine that low, less heat lol i just started a 1.365, then 1.32 then 1.30 ..go down each time i reboot heh
