Hi guys, had this PC for 2 years and now I want to overclock it a bit.
I wasn't thinking anything crazy, maybe 3.2 or bit more that won't be too dangerous.
I've been running prime 95for 30 minutes and my temp(stock) is 60-65c. Is that too high?
I got heatsink and aftermarket cooler, recently cleaned the inside of case, applied new paste etc. When checking temp in BIOS it's around 30c
I tried putting it at 3.2ghz, increased volatge 1.25 or 1.3 but temp went up to 70degrees when running prime95 for short while so I just went back to default.
Here's my spec:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119138 - case
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299 - MB
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115042 - CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171022 - PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121269 - VGA
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145 - RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003 - heatsink
I'm fairly new to this and if I play more with settings I'm afraid I'll screw something up so I seek advice.
Spent a lot of time googling and reading forums but I can't be too sure or find enough specific information.
Can you tell me what I should do? Exactly what settings to change and to what so I get nice stable speed? There are a lot of extra settings in bios for utilities etc, dunno what's useless or slowing it down.
Here are BIOS pics unchanged:
https://sites.google.com/site/nolimitss/bios1.jpg
https://sites.google.com/site/nolimitss/bios2.jpg
https://sites.google.com/site/nolimitss/bios3.jpg
https://sites.google.com/site/nolimitss/bios4.jpg
https://sites.google.com/site/nolimitss/fgdghfghfawe.jpg
Here's my spec:
