Hello,
The other day I finally finished my first build. The feeling that I gat when I pressed that power button and heard the post beep and then the screen came to life that was priceless!
Yesterday I spend the entire day trying to fix my core temps. Apparently cores 2-3 are about 13c higher then cores 1-2. I have a lapped HS (Ultima 90); I tried reseating it 3 times with no luck. I then tried the stock Intel fan, the difference was still the same. I finally grew inpatient and decided to lap the IHS of the CPU, but that didn’t help ether… The specs are in my sig & here are my final, idle temps.
RealTemp 2.5
Core 1-2 = 25c
Core 3-4 = 37c
CoreTemp 0.98.1
Core 1-2 = 34c
Core 3-4 = 47c
What program should I trust more RealTemp or CoreTemp? What cores do u think are giving the correct temperatures? 1-2? or 3-4? I assume the problem is with the faulty heat sensor; obviously now that I lapped the HIS I cant RMA the thing. What do u guys suggest I do to fix this?
Thanks
RealTemp 2.5
Core 1-2 = 25c
Core 3-4 = 37c
CoreTemp 0.98.1
Core 1-2 = 34c
Core 3-4 = 47c
Thanks
