mercury529
- Dec 19, 2007
Hello,
I recently purchased a Q6700 OEM and a ZeroTherm Nirvana cooler. I will be getting them later next week, and I wanted to ask a few questions beforehand.
First here is my rig:
Mobo: Asus P5Q Pro (P45)
CPU: Q6700 OEM
Aftermarket Cooler: ZeroTherm Nirvana
Memory: Corsair 2x2 XMS2 DDR2 PC6400 RAM
Case: Antec P180
1.) First, is there any general advice people would give for setting up this overclock that would make it different from a standard overclock?
2.) I have Arctic Silver 5 thermal paste. Would it be wise to use it with the ZeroTherm Nirvana and Q6700? If not, what would you recommend?
3.) Does anyone have experience with a similar rig? I believe the multiplier is 10x on the Q6700. So the max overclock without changing voltage is 4 ghz correct? What speeds would reasonable to expect with this overclock?
Thanks for any help you can provide.
CPU: Q6700 OEM
Case: Antec P180
