Hey all...so I upgraded my e6420 to a Q6700 yesterday and I've been having problems getting the machine stable at speeds above 3.3ghz. Mostly b/c A) not sure what to set voltages at and B) b/c the PWM temps are pushing 75C under load (prime95). I thought about removing the heatpipe setup and replacing the thermal paste before the install but I guess I didn't realize the temperature differences involved with the quad cores.
So first off...should disassemble the whole damn system and fix up the mobo cooler? I've got some Tuniq TX-2 paste that i can use.
Second ... since the Q6700 has a 10x multi, I have more options for higher speeds (400x9, 500x7, 360x10, etc.). Which is the best way to go? higher fsb or higher multi? Or does it all end up the same in the end?
3rd...I know the vast majority of people have Q6600s so I'm basing alot of my OC baseline attempts on those. Am I right in assuming that a Vcore of at least 1.5V is needed to get stable at 3.5 or 3.6ghz?
On that topic, the Vdroop on this board muddles things up a bit more. For instance, at this moment my settings are as such in the BIOS:
330 x 10, ram using a divider to stay at 800mhz
Vcore 1.375
NB 1.41
SB 1.09
Vtt 1.31
Vcore in windows (cpu-z, everest) idle is 1.34V and under load, the Vcore drops to 1.29V. Everything else pretty much stays stable. The vid listed in cpu-z for this cpu is 1.275.
Idle temps are 34/35/33/37 for the cores, 49C PWM, 42C Mobo Temp. Since i switched cpus, the BIOS temps are all wrong, so these are from RealTemp and Everest. I'm not sure how much more cooling i can stuff into my Thermaltake Aguila case...I've got 2 120mm (1 in 1 out), a 92mm window fan, and the Tuniq Tower 120. I'm pretty sure the cpu temps will go lower once the paste has set in.
Sorry for all the questions thought I'd cover everything before I forget. Also, you guys with quads running at 3.4 or above, can you hook me up with your BIOS settings so I have some idea what region to be experimenting in?
I had a similar thread in the intel proc. forum, but this seems to be the right place to discuss these things. Anyway, all help would be appreciated! Thanks.
Vcore 1.375
NB 1.41
SB 1.09
Vtt 1.31
