johnrhance
- Aug 28, 2008
I've been overclocking my Q6600 recently, but I seem to have hit a wall. I can't get it to post past 333x9 (3.0ghz) and it isn't stable at that speed. Here's a picture of my bios settings to be sure I'm right: http://i252.photobucket.com/albums/hh27/johnrhance/settings.jpg
I thought maybe I should up the voltage to the CPU, but I'm not exactly sure which option that is in this menu: http://i252.photobucket.com/albums/hh27/johnrhance/volts.jpg
So what option do I need to change to raise the voltage? If that doesn't work, did I just get a bad chip? I'm on a DFI Lanparty P35 and currently using the stock Intel heatsink. I'll buy a better heatsink when I know this chip will get past 3.0ghz.
