Sep 12, 2007 #1 J JD03Cobra Limp Gawd Joined Jun 4, 2005 Messages 392 Curious what software you are using to monitor the Quad core in Vista. Thanks.
Sep 12, 2007 #2 L l3ender Supreme [H]ardness Joined Jan 1, 2007 Messages 5,337 CoreTemp or SpeedFan. Just be sure if you use SpeedFan that you take into consideration that it gives temps 15° lower than reality.
Sep 12, 2007 #3 S Sphere 2[H]4U 2FA Joined Apr 13, 2005 Messages 2,389 Speedfan works straight away, with Coretemp you have to disable driving signing at boot.
