q6600 to q9550?
tissimo
I've had my Q6600 for 1.5 years now and kinda want to mess with something new. I dont want to jump into a i7 yet and with the recent low prices of the Q9550s I've been tempted to get one. Would it be wasted money?
My Q6600 isn't a great overclocker (only 3.2ghz @ 1.3v, and even with 1.5v doesn't like 3.6). I've tested my motherboard and it easily ran my q6600 at 7x450 so that would give me a top of ~ 3.8ghz (450x8.5) if the chip will go up there.
What are used q6600s going for now a days? $100? I lapped it so that would scare off most people I assume.
3.2ghz at 1.3V isn't bad. I'm surprised you couldn't get 3.6ghz. I'm wondering if it could be some other reason like MCH or RAM.
getting a q9550 might not deem any much more luck for the entry fee.
If you're not ready to jump on i7 yet, sit tight with the Q6600 imo. Switching processors seems like a lot of hassle for a small performance upgrade. I'd wait for Lynnfield.
I don't really think you would see much improvement switching to the 9550, but it should run cooler and will probably clock a bit better...
I would do it, in fact I did....then went for the 9650 and that's where I'm at now ....I'm putting together an i7 rig a bit at a time....but its not gonna be my main machine as of now.
As for the quad, $120.00 to $140.00 is about what I see them going for...the lap job might take a few bucks off of that but that depends on the buyer I guess..
eBay would bring more money than here , you might want to list it there.
In going from the q6600 @ 4.0, to the i7 920 I can say that the q6600 with an oc can hit stock i7 920 performance levels, and for me it just seems a little excessive pay almost the same for a step up rather than to save and get a true upgrade in a little while, unless you can get a good deal on the q9550. Also with your overclock I would say 2x2gb sticks of 1066 ram would help a lot, plus thats quite cheap right now. I know my q6600 would only oc so far with 4 sticks, but I cut it down to two and then was only hindered by the heat that thing puts off.
Are you saying the q6600 overclocked only reaches the i7 920 stock speed performance wise :eek:
Check out this hardocp article: http://www.hardocp.com/article.html?art=MTY0NCwxLCxoZW50aHVzaWFzdA==
In many cases the i7 920 loses to a qx9650 stock speed and overclocked!
I was saying that a q6600 can oc to at least stock 920 speeds for the simple sake of comparison my 920@ 3.02 got 16919 3dmarks on 3dmark06, while the q6600 @3.5 recieved 15852 3dmarks, wish I had more of a direct comparison, but forgot to bench the i7 before I overclocked it, and lost some of my q6600 benches, also the 920 is not using triple channel memory, another note is that the q6600 at 4.01 would get around 28000 in the everest benchmark cpu queen, while the 920 at 3.8 hits 35000+.
If you're bored and feel like doing it, a $100 buck or so upgrade after selling your other chip would give ya something new to play with. You could do that for now and keep it until Gulftown or Sandy Bridge comes out and then make the jump on that boat.
I done this a few weeks ago, sold a 3.8ghz capable q6600 for £100.00 gbp and got a q9550, solely cause i wanted to try something new. Im currently testing the new chip at 3.6ghz, so far ive found it to be a lot cooler to run than the q6600, windows feels a bit more snappy but no difference in gaming.
I think I'm going to hold out for now as there isn't any real improvement (unless I get lucky with a chip that OCs well) and will spend the $100 on another 640 Black HD for a Raid setup. Thanks for the input.
If ya haven't got that on your current setup that's your answer for sure. Do that man no question LoL. Get a few of em :) Or get a vertex for your boot and apps drive and then do raid 5 or 10 with your wd's for data. :) If ya haven't checked the reviews already here some. They fixed a lot of the crap issues SSD's used to have and apparently with the vertex series this is due to the help of some ex samsung employees.
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16820227393
http://www.bit-tech.net/hardware/storage/2009/05/15/ocz-vertex-ssd-review/11
