I have had my q6600 at 3.2 for a while now and the temps are about 38 46 44 38. Usually the middle cores are high while 1 and 4 are lower. I was just curious if these are good temps to be at for this overclock.
Things I have done so far:
- Cleaned my nirvana nv120 heatsink fan. The fan part actually popped off while I was holding it out to clean the dust behind it but I epoxied it back. This did not seem to effect the cooling at all. Got lower temps after I cleaned.
-Cleaned my whole case for dust and ordered the cables to free up some air space. I will try to get a picture.
-I have a 120mm silverstone fan on the drive bay pointing at the gpu which has the aftermarket cooler on it. I also have a pci exhaust fan right below the gpu.
Questions:
1) I have this case:
http://www.newegg.com/product/product.aspx?item=n82e16811129024
Would it be worth it to upgrade to an antec 900?
http://www.newegg.com/product/product.aspx?item=n82e16811129021
I like the case look and the price is not too bad. Also the 200mm exhaust fan seems like it would help with cooling.
2) Anything else to help cool it off. Only thing I can think is reapply heatsink paste for cpu. It has been on there for about 1.5 years I think.
3) I have the case currently on the floor next to me since the apartment I am in for my internship is small as hell. Would putting the case on a higher surface help? Ambient temp in my room is probably around 65-70F.
Any other suggestions I am open to. I am way sick of the Sonata III but if I could get the temps lower I would not mind since summer is coming up. I actually would not mind ocing it more to like 3.4. I have gotten it to boot but the temps are a little high and stress testing it drives it to 75-80C pretty quickly.
Questions:
