i have a q6600 running here and my speed fan 4.33 tells me that all 4 cores are running 9C idle and about 15C gaming. whats going on here are these true figures or is my speedfan broken
the pc is a dell xps 420
I have a tuniq tower, and my temps are something like 38/38/33/33
how are u guys getting lower then that!
i have a CM690case too
How do you run more than one instance of Prime95?
I tried because I would like to run Prime95 on all cores at the same time. I could see the application opened but it would go away.
Are you actually using Prime95 for those load temps now, or are you still using SMP Folding?
This processor can go higher than the manuf. temp max of 71. Here's my Q6600 with 2 of the cores at 78C. I ran these temps for more than 4 hours on a stress test of Prime 95.
