I've been having a problem with my CPU temps being way too high since I built this rig. My Q6600 with a mild overclock to 3.0GHz currently sits around 50-55 idle with a Zalman CNPS9700 (using the supplied STG-1 thermal grease and applicator)! I'm fairly certain it's not a case issue as temps only drop 3-4 degrees if I run it with the side of the case off. Everything is housed in a P180B with 4 120mm fans (1 in the PSU region, 1 up front, 1 in the rear, and one on the top of the case). Anyone have any ideas? Is it an issue of thermal grease? I've reapplied 3 times with no improvements, but each time I spread it on using the brush applicator that comes with the STG-1.
