I just got my q6600 today. I have a artic cooling pro 7 with Nine hundred case with 4x 120mm and 1x 200mm fan. I had a e6300 before running at 43c. my Q6600 is B3 rev, and its running at 21c idle, 27c load and its oc to 2.7ghz.
yeah speedfan why 15c ? That mean my e6300 was running at 70c load !
You only add the 15 for a quad.Core 2 duo reporting is correct, I believe.
Does Coretemp work with quad cores?
Oh dear me.
Running your cpu at low temps can shorten it's life... because the oil doesn't get viscous enough and premature wear can occur during boot startup cycle.
I recommend a small electric block heater mounted right in front of your HSF (remember to plug it in at night, a timer might be a good idea).
You might also want to switch to a low temperature cpu oil, something a bit thinner - maybe a 5w30.
Funniest post ever. To the OP, for reference Core Temp 0.95 reports my Q6600 @ 43ºC (idle) and around 59ºC (load). Anyone know the accuracy of Core Temp?
Oh dear me.
Oh dear me.
LOL I thought I was on my Civic forum, I was like WTF am I reading I know I'm tired but ...
My temp is close your temp. what is your cooler?
