marcostheblack
- May 9, 2008
Hi Folks, I've just upgraded to a GA-38X-DS5 MB, Q6600, sythe mine cooler, 2x1GB balistix PC8500 memory and 8800GT graphics card with a view to trying my hand at overclocking. I'm only running the system @ std clock at the moment but the temperatures are very high. With zero load all cores are sitting ~47 deg.C. With any load the temp jumps to the high 60's and low 70's and that's not even at full load.I have 2 120mm fans in the case 1 pulling air in from the front and 1 pushing air out at the back. There is also an 80mm fan pushing air out of the top. Inside the case feels quite cool. I would think the temps should be much cooler than that.
Any suggetions would be appreciated.
