neutronjockey
- Apr 9, 2008
Hey all.
I just finished a successful overclock on my G0 Q6600: rock solid at 3.4 GHz.
Temps maxed at 70C during the 24 hr P95 run. Idles around 50C.
Bumped CPU Volts to slightly above 1.4, RAM Volts to 1.925, VTT and NB up one click.
Stability tested with OCCT (1 hr) and P95 (24 hrs) no error. Extended gaming sessions show no artifacting and/or error. Was getting the nvlddmkm.sys error at first, but the bump to RAM volts fixed it completely.
All parameters with the exception of RAM Voltage are within manufacturer specs, and even the RAM voltage is a a small .025 of a volt. Max temp is pretty close to the rated 71C.
Just want a second opinion on whether you'd run this overclock 24/7. Thanks all.
