Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
When Idle'ing intel cpu's go into a halt state which lowers the processing speed. Try doing somethign that will strain the cpu, and the freq will go back up to normal levels. you can turn it off by giong into bios and turing enchanced halt state off.
yea your right, got scared for a sec because I was doing some test overclocking and then set it back to defualt and thought I fucked the cpu or something.
