Hi guys, i'm having a problem with my q6600 that i can't seem to figure out how to fix. when i'm running prime95 to stress test, only core 0 is under load 100%, the others are just idle. Here is the weird part, if i restart my comp and stress test right away when windows load, all cores are 100% under load, but if i proceed to just leave the comp on for a few minutes before running prime, only core 0 is under load.
this happens even at default settings in bios. everything was working fine before i took out my mobo/hardwares to install my xigmatek backplate to screw on instead of using the push pins it came with. any idea what the cause might be?
