Note: Before I get started, yes I have used the Search feature and have read for 2+ hours on specs for each. Some of it is old, though, and I'm hoping for more of a direct comparison with this thread...
As the title says, I'm putting together a budget gaming/work machine. About 75% of the time I'll be using the system for work that involves standard Office/web browsing, as well as writing server admin scripts and running test virtual servers. The other 25% will be gaming. The motherboard will be a GA-EP45-UD3R with 4x2GB RAM to have the RAM for hosting virtual machines. I'm really torn between the E8400 and Q6600 procs. I can evaluate the usefulness for all of the work stuff, but I don't know which would be better for gaming. Which is more likely to perform better with a mild, not crazy, overclock? I won't be overclocking to the point that there's any stability impact. This will be my work machine, after all.
Anyone got experience with both and want to share their experiences or just throw out an opinion?
Thanks in advance!
Thanks in advance!
