Q6600 OC'd but it doesnt seem right
wildkatz84
I have my Q6600 OC'd to 3.0 Ghz by changing my FSB to 333. I couldn't get it to pass prime95 without any errors at anything over 3.0 GHz. It fails prime95 at 3.0GHz if I have my vcore anything less then 1.375 volts. I mean its solid at 1.375 but that seems so high for only a 3ghz oc w/ 1333 fsb. Almost everyone with a Q6600 that has it OC'd either has like 1.2 vcore at 3 GHz or they are getting like 3.6 GHz with the same vcore I'm using to only get 3 GHz. Did I get a really bad chip or am I doing something wrong?
Asus P5Q Pro
Q6600 G0 stepping
Zalman 9500 cooling
Antec trio 650w PSU
XFX 9600 GT video
4 GB of crucial tracer ram
Asus P5Q Pro
Q6600 G0 stepping
Zalman 9500 cooling
Antec trio 650w PSU
XFX 9600 GT video
I think your voltages are probably fine. What is the VID of your chip? Most of the Q6600’s I’ve worked with have had a VID of 1.3+ which means they are going to take more than 1.2 even at stock. My Q6600 with a VID of 1.3125 takes 1.5vcore to be completely prime stable at 3.6.
How are your temps? Are you remembering to set the ram divider correctly as you bring up the FSB, etc?
I see the three of us share the same CPU and Mobo. 1.375v at 3ghz does seem high but not it's the end of the world. Is your CPU stable beyond 3ghz at 1.375?
I am at work now so I'll check these things when I get a chance at home. How do you check your VID? RAM divider is just set up to whatever is default for my MB. My temps are good, I get about 25 degrees F when idle and no more then low-mid 50s F when loaded. I use real temp with a tjmax of 100. Thanks for looking!
That does seem like excessive vcore. Try bumping the NB voltage up a notch, that might be holding you back.
On a side note I haven't seen a G0 that couldn't do 3Ghz at stock vcore.
What I mean is like if I was running at 266 stock FSB, and I used a 3.0 ram multiplier to have my ram run at ~800Mhz. If I didn't adjust that ram multiplier and bumped the FSB up to 333, that would mean my ram is now running at ~1000Mhz, which, assuming I was using 800Mhz ram would probably be more likely to cause a failure than the CPU speed. Just make sure it's keeping your ram within spec in relation to your FSB; I don't recall that it adjusts it automatically for you so if you haven't changed that yet that may be the problem.
You can usually see your VID in your bios (should be your stock vcore, which isn't the same for all chips) or CoreTemp will tell you what your VID is.
the only way i can oc to 3.2ghz is cuz the VID of my q6600 is 1.2125 and most are over 1.3 for the g0 step
Ermm.. temps idle at 25F???? you on liquid nitrogen?
ehh.. I'm running mine at 3.6Ghz @ 1.45v. My board is kinda weird tho - failed prime miserably with 400x9, but stable with 450x8 - I'm still pondering about it.. well, at least its 3.6 with 1800 FSB :p
Try bumping up the N/B voltage.
I have a q6600 with a VID of 1.3125, and it takes 1.3625 vcore to run it at 3.1GHz prime95 stable. As D3z said, try upping the NB voltage (or the VTT)
So are all the newer Q6600 G0 batches hard overclockers?
Do they all need a lot higher vcore to even get a slight overclock? Or is it still random luck?
Or is it a mixture of both?
Kind of sad what happened to this chip if that's the case :(
My bad its 25 C, my core 3 is only 20 C idle, its my fav core.
Seems like randow luck, but there is a trend developing that the earlier released G0's were lower VID chips and generally clocked higher at lower voltages. But that doesn't mean that a 1.325 VID chip won't clock to 3.6Ghz at decent voltages.
Luck of the draw, but chances are better with an earlier chip.
That's my $0.02 anyways.
I got my Q6600 exactly almost 1 year ago. VID 1.225 and That's what it's running at.
*shrug*
:eek:
My problem is that my Q6600 (1.325 vid) will pass all of the tests/benchmarks at 3.0 (333fsb) but will give random errors and an occasional BS during normal usage. This is on a MSI P6N SLI board. So my question is- what should I try first to get it stable at 3.0, NB, VTT, increase vcore?
can't hurt to bump up the NB voltage.
Experiment. You're not going to kill anything unless you go crazy with the voltages.
4gb of memory... take that NB voltage up to 1.41 or so and give it a shot. Ive had 3 GO quads. One could not get over 356mhz to save my life. It took 1.5V vcore to get it there. The others hit 3.4ghz @ 1.375V 8x425. It took about 1.55V to get it stable @ 3.6 but was not worth the extra heat for me. The one that didnt OC as well was a newer GO. 3ghz still is not bad. Keep playing. Sounds like there is more in it.
