Right,
i'm trying to overclock my q6600 but i have a weird problem.
This is my setup:
Q6600 G0 stepping
Asus maximus formula with CPU cooled by thermalright 90 ultra and a Scythe Kaze fan
NZXT lexa case with 4 fans,good airflow if you'd ask me
Bios version 901
Geil 800Mhz DDR2 8Gb
Antec truepower trio PSU
Got the mem cooled with an ocz active cooler covering all 4 dimms
I got overclocked for 25 % now , FSB 333 and mem on 667. I tried with VCore volts of 1.2 to 1.4
For example
I read the voltages on Asus Probe, guessed that would work best as an asus tool for an asus mobo?
then i tried some info i found for the quads
drelax to 0 with dram booster disabled ai clock on auto or light , static read control enabled and i gave the cpu pll volt a bit more juice and the fstb too. PLL to 1.712 and the fsbt to 1.504.
Could you guys tell me what I'm doing wrong or ask me for more info if you need that to come to a solution?
The temps i'm running stable non overclock is around 50 degrees C everything
When overclocked, non stressed something above 50 and max around 60, NB and SB at 50. I think everything around 50, max 60 should be ok right?
I'm also thinking off getting some water cooling for the sb and nb, would that help a lot?
I wanna get 3Ghz out of this set
I'm now gonna try with the settings adjusted a bit too what was written on this forum, to overclock C2D and C2Q guide. But I doubt it'll do fine, as soon as i edit something the SB voltages keeps shooting up after 15 mins of stressing.
This is my setup:
Q6600 G0 stepping
Bios version 901
For example
I used occt to stress the system. It seems to run stable but after 15 minutes my SB voltage goes from 1.17 to 5 volts ????BIOS 701
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : Auto
CPU Ratio Control : Manual
-Ratio CMOS Setting : 9
FSB Frequency : 400
FSB Strap to North Bridge : 400
PCI-E Frequency: 100
DRAM Frequency: 800
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 4
RAS# to CAS# Delay : 4
RAS# Precharge : 4
RAS# ActivateTime : 4
RAS# to RAS# Delay : 12
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
DRAM Static Read Control: Enabled
Ai Clock Twister : Light
Transaction Booster : Disabled
-Relax Level 0
CPU Voltage : 1.38750
CPU PLL Voltage : 1.54
North Bridge Voltage : 1.49
DRAM Voltage : 2.00
FSB Termination Voltage : 1.26
South Bridge Voltage : 1.050
Loadline Calibration : Enabled
CPU GTL Reference : 0.63x
North Bridge GTL Reference : 0.67x
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : 1.50
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED : Disabled
CPU Spread Spectrum : Disabled
PCIE Spread Spectrum : Disabled
Advanced CPU Configuration
- Ratio CMOS Setting : 9
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Enabled
