eva2000
- Apr 14, 2002
Just a preview for now until I figure out how Q6600 Kentsfield performs on Asus 680i Striker Extreme
Seems Asus 680i Striker Extreme still has an FSB limit like all 680i boards when it comes to Kentsfield. Although it seems Asus 680i Striker Extreme does a bit better on FSB front than other 680i boards.
H20 setup:
Settings used:
Asus PC Probe2 reported PSU rail voltages:
Asus PC Probe2 reported voltages vs Digitech QM1538 Digital Multimeter measurements while under load
+3.3v rail = 3.26v vs 3.387v real
+5v rail = 4.78-4.89v vs 5.02v real
+12v rail = 11.78v vs 12.23v real
H20 setup:
System:Swiftech Apogee -> Radiical Triple fan single pass radiator -> T line -> Swiftech MCP655 @12.25v -> Swiftech Apogee
- Intel Core 2 Quad Q6600 QUPT B3 Step 7
- Swiftech Apogee/Radiical Triple Single Pass/[email protected] Kayl Custom 100W Psu
- 2x 640MB Gainward 8800GTS SLI
- Asus 680i Striker Extreme rev1.0 0402 bios
- 2x1GB OCZ PC8000 Titanium AlphaVX2
- 1x 160GB Seagate 7200.7 SATA NCQ on SATA2 port
- Pioneer DVR-05 DVD Burner
- 600W OCZ EvoStream Modular Power supply
Settings used:
AI Tuning: Manual
Nvidia GPU Ex: Disabled
LinkBoost: Disabled
FSB - Memory Clock Mode: Unlinked
x FSB - Memory Raio: N/A
FSB (QDR), Mhz: 1345 (means 336FSB)
Actual FSB (QDR), Mhz: 1344.4
MEM (DDR), Mhz: 807 (means 403mhz speeds)
Actual MEM (DDR), Mhz: 806.7
Vcore Voltage: 1.5 set (1.37v bios/1.36v windows idle/1.34v windows load - 0505 and higher bios fix the vcore issue but 0402 bios more stable for both my E6600/Q6600 cpus)
Memory Voltage: 2.000v
1.2v HT Voltage: 1.3v
NB Core Voltage: 1.55v
SB Core Voltage: 1.50v
CPU VTT Voltage: 1.4v
DDRII Controller Ref Voltage: AUTO
DDRII Channel A Ref Voltage: AUTO
DDRII Channel B Ref Voltage: AUTO
tCL (CAS Latency): 4
tRCD: 4
tRP: 4
tRAS: 12
Command Per Clock (CMD): 2 clock (2T)
Advance Memory Settings
tRRD: AUTO
tRC: AUTO
tWR: AUTO
tWTR: AUTO
tREF: AUTO
Async Latency: AUTO
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
MCP PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
LDT Spread Spectrum: Disabled
CPU Internal Thermal Control: Disabled
Limit CPUID MaxVal: Disabled
Enhanced C1 (C1E): Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
Enhanced Intel Speedstep Tech: Disabled
LDT Frequency: 5x
PCIEX16_1 Frequency (Mhz): 100
PCIEX16_2 Frequency (Mhz): 100
PCIEX16_3 Frequency (Mhz): 100
SPP<->MCP Ref Clock, Mhz: 200
