Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hi i just got my new pc Q6600 with artic freezer pro 7 as my cooler with artic silver 5 for my thermal paste my temps are 47-49c idle are these temps normal? Also whats the highest temp my quad should run at.
With my B3 Q6600 at 3.3 Ghz using a Tuniq Tower 120 on a normal day with low 70s(F) ambient temperature Im seeing idle temperatures of about 45-48c and load temperatures of about 65-70c. Im using the auto voltage option on my Gigabyte P35-DS3R, CPU-Z showing 1.376 at idle and 1.328 under load. I took this CPU up to the mid 80s(C) using sub-standard coolers (stock, then a mini-typhoon which was only slightly better) on a fairly regular basis for a few weeks before I got my tuniq-tower 120 and it ran fine and was stable though it still made me nervous. All temperatures were measured using coretemp using 100c TjMax.
I have a Q6600 B3 stepping with just a tuniq 120 tower. I overclock it to 3.3Ghz and I get 35c-40c Idle.45c Load. I hardly ever see it 50c, but I'm afraid that this summer I will see such high temps.
Ok i went into bios my DS3l is giving 1.3125 for Vcore temp is that normal???? i got a Tuiq tower it lowered my temps a little i guss to like 40c idle.
That seems normal for a B3. I don't own one so I don't know personally, but from what I read as far as reviews it sounds right. I'd expect a G0 to be about five to ten degrees cooler...
