SovietSpartan
- May 1, 2008
I'm a little bit worried about my summer temps.
Current room temperature is 85F or 29c. Not hot enough for air conditioning but it can get to 115F or 46c any day now.
Currently while Idle I get 45c, 47c, 38c, 39c. Under Prime95 25.6 load, 71c, 71c, 66c, 63c.
For cooling, I have a Thermaltake Armor+ with two Antec Tricool Fans (taken out of my 900) pulling in air from the bottom of the case, another Tricool pulling in air from the front of the case, but this air is warmed up by the 3 hard drives behind it.
Attached to the back of the harddrive case i have the stock Thermaltake 140mm Blue LED fan which doesn't feel like its blowing much air. There is a 23cm fan attached to the window blowing in air. I have the stock Thermaltake 120mm Turbofan attached to top of the case sucking air out and I have a Scythe 120cm 110CFM fan blowing air out next to the I/O shield.
All fans are set to high, I believe the 3 antecs pull in about 79CFM each on high. I don't know about the Thermaltakes. I do have 3 more Scythe 120mm 110cfm available but don't wanna use them becuase they don't have the cool blue leds.
Also my power supply pulls air directly from outside of the case and expels it outside of the case and in the front of the computer 5 drive bays are not in use and allow air through the dust filters.
I am using a Zalman 9700LEDw. artic silver 5 on a Q6600 o/c'd to 3.4ghz. On an Asus P5E, FSB at 375mhz and 4gb AxeRam memory at 1200mhz cooled by an OCZ XTC memory cooler. MB temp sensor shows 36c, this board doesn't give temps for southbridge or northbridge. Also in the system is an MSI 8800gt with the zalman heatsink GPU temps is 41c and PCB temp is 38.
Are these temperatures safe considering the room temp? And I read somewhere that you don't want your CPU temps to get to 70c at all and your motherboard temps to 45c. While playing games mobo temps get to 45c and core temps are up to 60s.
Thanks guys.
Thanks guys.
