rottweiler
- May 13, 2000
It's been a while since my last build (6/2004) and you can see some of it's stats in my sig (Main).
What I basically use my system for is:
Personal web site, not much traffic.
FTP server, almost no traffic.
Some gaming, but not much and nothing too new. I bought Hellgate London a few weeks ago, but haven't opened it yet.
Backup DVDs and Xbox/360 games.
After looking around I have decided that I'd like to get a Q6600. It just seems like a good all around CPU that should be good for another 3 years, with my usage, while apps start to take advantage of more cores.
I saw [H]ardOCPs review of the Asus Maximus Formula and that looks good. Any other suggestions?
I would like to overclock just for the hell of it, but won't try to break any records. Just air cooling. What should I look for in terms of a CPU fan. Also what are decent brands for RAM? I saw OCZ had 4GB DDR2-800 for $55. Would that be good enough? These ram prices are still just amazing to me.
For a video card, is a 512MB 8800 GT overkill? They seem to have a good price/performance ratio.
My current power supply is a PC Power & Cooling. I assume I'll need a new one since the motherboard pins are probably different and I don't even have a PCIe video card. I like PCP&C and will probably stick with them unless someone has a good reason not to. It looks like pricing is not yet out for their new turbo-cool line. Is a Silencer 750 good, I like red, or should I wait until the turbo-cool 860 is available? How many Watts do I need? I know with PCP&C it's usually less than others.
I already have 3 1tb WD green drives on the way to replace my 6 320s. One thing I think I need to upgrade is my raid controller. I might ask specifically about this in the Disk Storage Systems thread. If I want to take advantage of SATA 2 do I need a PCIe controller? I don't think I need a hardware based controller having 4 cores so that should open my options up and hopefully lower price. I still want 8 ports so I can add more drives later when needed.
I'm not looking for a budget system, but don't want to spend $3K which is about what I spent on my last system. Although I don't need a monitor this time, and those 24" were not cheap when they came out. I've already put down $700 for the hard drives. If there are expected price cuts in the next few weeks then I can wait, I'm in no rush. But since prices will always drop I'm not going to wait 4 weeks to save $100 on the whole setup.
Thanks for any help.
