I think the only G0s out are ESs. I have a P5K deluxe.
What are your temps?
BTW, just a side note re: temps.
When I got mine, I found out in the first five minutes that I absolutely COULD NOT use the stock Intel fan- the chip overloaded it almost instantly when I stressed it even at stock speeds/volts. Did you guys have the same problem?
I hooked it up to a Thermaltake Rocket WC kit (Reserator knock-off) but with two rads (bought two kits, one was sacrificed for its tower), and it's still running 60C-66C loaded with a 120mm Panaflo pointing directly across both. I know it's a cheap block, but it does the job- both towers get pretty hot.
hmm... but that shouldn't be an issue with the Q6600. I believe higher C2D has soldered HSFs... but I didn't bother checking my quad with stock HSF
Not true, Conroe-L and Allendale (e4x00, e21x0, and Celeron) have thermal paste- not solder- under the IHS.LGA775 processors ALL have soldered IHS (Integrated Heat Spreader). That is the metal thing that is on the actual processor itself. None of them have a soldered HSF (Heat Sink and Fan). The HSF assembly is always a completely separate entity, it would be an extreme oddity to have one that is permanently affixed in any manner.
