Q6600 - Are These Temps High?
Prick
Speedfan and Core Temp are reporting different temps...How are my temps? Is there a better program out there to measure temps? Temps were taken with computer at idle...Also have Ultra 120 Extreme...
Core Temp
TJMAX 100
40
40
39
39
Speedfan
26
26
24
24
CPU 46
Sys 35
Aux 119
Not sure how the temps can be so different...
Core Temp
TJMAX 100
40
40
39
39
Speedfan
26
26
24
24
CPU 46
Sys 35
Aux 119
What excatly are you complaining about? 40/40/39/39 is perfectly OK. With SpeedFAN, IIRC, you have to either manually add 15*C in your head, or write it in to the app to correct for that. There's a place where you can put that adjustment in, I just forget where (and at work, so I can't find it).
Found it:
Click "Configure", click "advanced" tab, select your chip (mine reads INTEL CORE at $0 on ISA). Change the value of each "temperature offset" to "15". Click OK.
