So there's no danger of damage if I go straight to 3Ghz instead of doing it incrementally?
(supposing the the q6600 can reach 3GHz without problems, which q6600 doesn't?)
now comes a newbie question:
my q6600 has a fsb of 1066
my ozc pc8500 mem is running fsb at 266 or 400? what about ram speed?
I'm looking forward to a humble 3Ghz OC and the mems at 333.
Is that possible at all with my setup?
I am a complete noob at OCing and I am trying to learn as much as I can before I build. From what I understand of what you are saying there, you can just adjust the multiplier each time you bump of the FSB so you arn't OCing the RAM?Right your processor is quad pumped so 1066 actually = 266.5MHz* FSB set in your BIOS (if you can set that, otherwise 266 or 267 will do) .
Your RAM is PC8500 so thats 1066 but DDR2 means it doubled so really that = 533MHz
So at stock in your BIOS set FSB at 267* now your RAM speed should be dictated by what ratio you choose to use in your BIOS, 2x267 = 534 bingo!
Set your ratio to 1:2.0
Obviously as you O/C you gonna have to change this ratio, lets use 3GHz as an example:
You're gonna use a FSB of 333 (with a multiplier of 9), so to keep using your ram at its stock frequency the ratio will have to be 1:1.6 (333x1.6 = 532.8)
I hope this explains what you're asking, the figures can be tweaked very slightly but not the ratios.
Edit: of course if you want to O/C the RAM also then of course the ratios are different, i just hope I've explained it clearly enough to show how it works
the fact that I am using pc8500 (533), does it mean I can overclock easier than with pc6400 (400) for instance?
Since you have PC8500 ( 1066 mhz ram ) you can change your ratio. Like 1:2 or more. Your cpu will be running at 312mhz x 9 and your ram at 624mhz with the ratio 1:2. I don't know what your board ratio have but you can go higher to take advantage of your ram speed for more performance without overclock your ram..
Your RAM is good for 533mhz (DDR 1066Mhz)
Right now you are running it at a little over 300Mhz (DDR 600Mhz)
To increase or decrease the RAM speed, change the FSB / RAM divider.
So true. My G0 does 3.2ghz @ 1.300v ...My quad first boot went straight to 3.2. 5, 10, 15...just a big waste of time. 99.99% will do 3.0, so dont waste your time.
Disable EIST and C1E when overclocking. When you get a stable overclock that you are satisfied with, try enabling them again. BE WARNED, EIST and C1E do NOT work with anything less than the original multiplier (for q6600, it's 9x).
EIST = Enhanced Intel SpeedStep technology - allows the system to dynamically adjust processor voltage and core frequency, which can result in decreased average power consumption and decreased average heat production.What is EIST and C1E?
You could put the FSB up to 400 and take the multiplier down to 8 which would make 3.2 ghz, but it is really touch and go whether your motherboard and CPU would be happy to do this. The memory is fine, though if it is possible you could try lowering the timings a bit.
