matrix563
- Sep 1, 2006
Currently I have my Q6600 build with 680i evga running about 70-73c using prime95 25.6 (so 4 instances going)
real temp reports my temps at 70-73c. prime95 is running small fft's.
when i run a blend i get a max temp of around 55-60c. is this normal for it to be so much higher using small fft's instead of a blend?
i'm asking because i plan to run seti on my quad and i think it performs closer to a blend test in prime95 instead of the small fft test in prime95. 70-73c temps are just too high to run seti all day
. thoughts?
