Q6600/8800GTX expected 3dmarks?
Z
Ziontrain
Guest
I know 3dmark06 scores don't mean much, but I'm just curious...
A Q6600@3.6 and a stock cooler, slightly overclocked 8800gtx...
What scores can I expect at default 3dmark06 settings?
(My parts aren't here yet...)
Awesome. Alot better than like 4k I was getting from a current rig..can't wait! :D:D
Man if you think it 'plays' 3DMark great wait until you play an actual game! :)
If you are on XP you should get 15k+, Vista 14k+. My Q6600 is only at 3.4ghz and my Ultra has a weak overclock that a GTX can probably get,and I score 14.3k in Vista X64 and was about 15.5k with same settings in XP SP2.
A touch under 14k for me(8800GTX @625/1500/2000), but running x64 vista. My older AMD rig gets a touch under 9k in XP.
3DMark doesn't matter. Scores fluctuate as much as 200 points between runs and don't mean anything anyway.
We're talkin about a GTX, not GTS.
BTW, that score seems kinda low for a GTS, I would expect 15k
The GTS should be better at lower res's, so that is why the GTX should score around the same, even thought it is more powerful at higher res's?
How can I increase that score, I'm maxing everything I got right now.
My CPU is only dual core, and that can start to make a difference when you begin to max out the power of your card. And a combination of the crappy L2 stepping and a Zalman 9500, I can't put much more voltage in it.
My card however, at 670 core and 1100 ram, it was unstable. 750 core and 1050 ram runs perfect though. Any higher on the ram and it becomes unstable, I tried 800 core and 1050 ram and it started overheating and FPS became really choppy quickly. Throw on a better cooler and I should be able to do those numbers.
Next on my upgrade list:
Q9450 or Q9550... depends if I can get to 4.0 or 4.2GHz on the first chip.
Thermalright Ultra-120 Extreme
9800GTX
Thermalright HR03 GT.
Nah, similar score for similar system here. You're forgetting the ridiculous weight 3DMark gives to the CPU. C2D at 3GHz will get a smaller 3DMark score than a C2Q at lesser speeds in 3DMark, despite the fact that 99% of games currently out will not take advantage of the 3rd and 4th core in the slightest and the C2D will win out in actual game framerates.
