Q6600 @ 3.5 ghz
annaconda
Ok here are some new results, or i should say better memory results.
VCORE = 1.5(Bios) but 1.42v (in windows or effective)
System Setup:
Q6600 @ 3.5 ghz.
XFX 680i Sli Motherboard
X1900XT 512MB
4GB OCZ PC6400 @ 1002 mhz (5-5-5-15)
DVD Writer.
ATI 650 HDTV Pro.
500 watts Ultra X-FINITY.
Water cooling Setup:
D-tek Fuzion
MCW60
MCP655
2 X 330 MCR Radiators
Micro reservoir (swiftech)
6 x 120mm Yaat Lone fans.
1/2" tubbing.
Temperatures:
Idle = 32C ---- 35C
Load = 48C ------50C (MAX)
I'm guessing this is a B3 stepping do you have any info on the CPU batch? Oh and congrats nice OC, my gigabyte board unfortunately isn't up to the task and I'm sitting at 3 ghz
Just look at cpuz and you will see it's 6 B3, thus a B3 stepping. G0 isn't available yet.
Very nice overclocking for a Q6600 so this encouraging :)
A revision B3 Quad happily running at 3500 MHz confirms my suspicions. The soon to be retail G0 stepping may not overclock significantly better than what's presently available. Intel releases some engineering sample (ES) processors to the major review sites to create some excitement but no one will ever notice a real world difference between a G0 stepping and what you're running now annaconda. Great work! :D
Why not run Orthos like everyone else. It's a little simpler than multiple versions of Prime95 and does the same thing. Your core temperatures are excellent so with a little more core voltage I think 3600 MHz is quite possible. I need 1.48 volts while running Orthos to get 3600 MHz out of my Core 2 Duo and I think your Quad will be very similar.
I agree with this and this is especially true for those who have modest goals of running at 3.0 - 3.2 GHz, not more. I have this goal in my own mind since it's out of my mind to buy a watercooling rig to cool the Q6600 when there is so little performance difference gained with 200-300 MHz overclocking.
Well here are the Results with Multiplier @ 9, and Super Pi. I can even post @ 4 GHZ, but my chipset cooling is holding me back. I mean i have only single low noise 80mm fan on the chipset, which is not even putting enough air on it. If i switch to water cool chipset then i thing 4GHZ would be accessible.
But man oh man, i had e6300 @ 3.3 before and trust me big big performance difference. I am loving it. Now i can run 2 Virtual PC Servers + Play C&C3 + Record HDTV :D
well you say you notice a big difference.. Okay. Is it just due to the fact of running more programs without being slowed down? elaborate. :p
hahaha
michaLcoughliN,
If your running a multi threaded app, a quad should decimate the E6850 that you stated you were going to buy. You've said over at XS that quads are over hyped. So buy your dual core and be happy.
I'm sure you've read the review here for Supreme Commander, that's a good example, here's a quote from the review:
Apples-to-Apples Summary
All three sets of tests show a distinct difference in performance between single-core, dual-core and quad-core CPU. It doesn’t matter if we are at a high GPU type of setting at 2560x1600 or a more CPU dependent setting of 1024x768 with all the eye candy off, this game benefits most from increasing CPU cores. Where the game is playable at 2560x1600 and 1600x1200 maximum in-game settings with quad-core, it is not playable with dual-core. Nowhere is the game playable with single-core under Windows Vista.
Yes when i say big difference, it means every way. For example, i can run more programs as you said simultaneously, plus 8MB cache vs 2MB really help in running those programs faster, and the clock is up.
My 6300@ 3.3 was slower as compare to Q6600 @ 3.5 even if you take 2 cores of it. (200mhz more).
michaLcoughliN,
Well I will probably end up buying both. And testing for myself.. FYI.. money is made to spend my dear friend.
Well Q6600 has gotten a big hype without any proof within the past month. Now people have actually been showing their results. And have becoming impressive.
Even with B3 stepping. since we dont have much g0 stepping benches, who is to say they will do any better. Apparently people are just assuming they will. who knows at this current point
I still have 10 days ;) if i can not justify, I shall buy both and have my own thread,
At this point undecided. Whatever I plan to choose, a year down the road, another cpu will come out. And kickshit me for buying this so does it really matter?
Upgrading is continuous, and tideous all at the same time,
Dude like you said what ever you buy will be no 2 in the next couple of months. This will never stop, no matter you buy Q6600 or 8 Core processor.
It is good for you that you have money to examin both processor, but people like me who cannot afford both always go for high number and it is simple math my friend 4 is bigger than 2. :D
Where'd you get the ATI 650 HDTV? since it isn't slated for release until november? :rolleyes:
man i love those dual radiators, i can even run my q6600 passive on those two @ stock speed, and there will be no problem. Actually i did tried before overclocking and it was nice idle = 40c and load 50c.
Before that i was running totally passive AMD X2 3600 on those big boys, and temperature never went above 40c.
First of all, this confirms nothing, who knows, maybe G0s can hit 4GHz on water, we know nothing until we see it.
And second, he's using water cooling, 3.5GHz really isn't that great.
I know, geez, 3.5 on a quad is so slow.:p :rolleyes:
What I do not understand is why people are waiting for a new stepping to increase speed, when they have to wait that long. Isn't it an inherent waste to wait a month extra to get an extra 100-300mhz out of a CPU, thus saving you maybe a few minutes a day of constant CPU usage? The only reason this makes sense is for those that purely want to show off their machine online or in their signatures. (I am pretty much joking but I am sure its the case for some!)
I think i said that before, but let me repeat again. I can post @ 4GHZ, but because my chipset is on air and i mean really low air, i am limited to 3.5ghz.
If i switch my chipset to water too. i can go higher.
390fsb isnt much at all for the 680i. Ive seen more then a few systems with passive cooling up to 450mhz.
