cr!m$0n.$ky
- Jun 6, 2007
Does any1 know if a q6600 is overclocked to 2.66 GHz, will it perform the same as the qx6700 if the temp was kept down?
Just make sure your cooling is good. I got my Q6600 in yesterday: running STOCK SPEED AND VOLTS under a Zalman 9500, I'm still pulling 67 degrees Centigrade at 100% load (Folding@Home SMP client x2 in VMWare). I'm definitely resurrecting a water cooler for this. I'm also slightly afraid of how the Intel stock fan would've done.(Yes, this is correct- my e6400 @ 3.2 often broke 55C. These 90+ days in Jersey are awful for computers.)
From what I have read, and keeping in mind I have not overclocked anyting before, 333 FSB with an 8 multiplier would give the 2.66??
Would there be any need to increase the Vcore voltage?
I have read that you need faster memory to handle faster FSB, I assume that the Corsair at 4-4-4-whatever be fast enough.
lol.....that's chump change compared to the 117 we were getting last week in Phoenix.
I assume that instability / crashing would be a sign that I need to increase Vcore voltage?
From what I have read anything less then 60ish deg. C is ok as far as temps go?
Thats pretty hot.....
When my room is at 80 im getting around Mid 30's on all my cores
I plan on running it just at stock speed with a Tuniq tower. Im not a big fan of wc, so would rather stay with air. But have to see how it goes.if your room hits 100f, its probably a good idea to leave your cpu at stock speeds. or you can always go watercooling.
