Q: Which rig to put inside which case?
E4g1e
Right now, my current rig is in the sig.
I went out and got myself an Antec Super Lanboy case today. I will also get myself a TruePower 2.0 430 PSU.
The question is, I am considering building another rig - most likely to replace my very noisy "guest" rig.
So, I will ask two questions:
First, shall I keep my current main rig in the older Antec SX1035B case (which isn't quite cutting it because of many obstructions) or move it to the Super Lanboy with TPII-430 PSU?
Second, which configuration shall I put in the other case (the one not being occupied by the components for my main rig)? An Intel 2.8C P4 or an AMD Athlon XP 2600+ Barton?
I would appreciate your replies.
Oh, well, no replies.
Well, I decided to put my main rig's components into the new case equipped with the TPII-430 PSU anyway. The other case with the SPII-500 will house my previous Intel parts with a spare hard drive and a spare optical drive.
Thanks anyway.
