midlife chav
- Apr 30, 2006
Hellooooo,
On the Aspire Qpack you have a digital display on the front, this tells you the temps of the board and the cpu. on the inside there are 2 wires that are flat packed with little thermostat type things on the end.
My question is were do you put these things? does the cpu one go under the heatsink?? and i think the mobo one might go under the Northbridge heatsink, but i am not to sure.
