Q-pack prob
sinplicity
I have the q-pack and the MSI RS480M2 with two sata drives my prob is my hard drive indicator light doesn't work. I have them correctly installed on the mobo. Is there a different way you are suppose to hook them up on a sata hard drive? This is my first leap into the sata world. Thanks
sure have, and still nothing on either the hard drive indicator light or the battery light
My sensor works for about a minute and then the hd temp drops and drops from 29 until it displays "LL". I know my HD isn't that cold. I stuck the sensor onto the CPU and it still displays LL. I'd prefer it not work at all than pull this weird crap.
My HDD light doesn't work either.
Also, when I hooked up my front audio ports, the 2 front speakers quit working, all I had was center/subwoofer and rear surrounds. And the front headphone plug was silent. Unplugged the front audio cable, and it came back.
Also, my front USB ports don't seem to work. I plugged the cable into my MB (tried both USB extension plugs) and nothing.
At least the fan works. :rolleyes:
