If I were to do the vcore volt mod on the asrock dual sata, what do I have to worry about (other than obvious solder errors)? Do motherboard volt mods generally work for ALL processors that the motherboard supports, or are they usually specific to core/family?
I just want to be able to get higher vcore than 1.45 volts, but in a year or so i want to upgrade to an opteron 165/170, and was wondering if the vmod will affect this transition.
