Q about about AWC-1
Cryptic
On my display for my Kingwin AWC-1 Water kit the pump illistration runs for about 5 secs, then stops for 1 or 2 then starts again. The manual says the picture only stops when the pump stops, but it seems odd to me that it stops every couple seconds. I was wondering if anyone who has this kit has the same thing happen or if its just me? Thanks.
Edit: on the same note the picutre for the fan stops moving and starts again at the same time as the pump picture, but I know the fan isnt stoping as I can hear it...so I'm assuming/hoping its just a glitch, correct?
If the pump and rad fan motors are fine then don't worry about it. It's not exactly a "high-end" device so don't expect too much from the interface.
Don't worry about the display, both of these devices have a buzzer hardwired into the power line (I've dissected mine :D) and if either of these fail, you'll get a very loud, very high pitched noise telling you soemthings not right.
yeah if something isn't right it will make that loud annoying bEEEeeeEEeeepppp....what kind of temps do you get with your kit my temps are in my sig..
I'm getting about 36c idle and 44c load...which is a huge improvment over what they were before...so I'm happy with it. Thanks for all the feedback.
Like I mentioned in another thread, just watch out for leaks and cracks in the resovoir, especially around the fill hole.
