Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Why do they make 20 inch Flat and 20.1 Flats. I really dont understand the difference.
Another Q, do you want the contrast ratio to have a small or big number.
The difference between a 20" and a 20.1" is .1" Different companies make the panels and they make them with different manufacturing processes and they choose the one that works best for them.
Higher contrast ratios are better but it's not the only thing that decides whether a panel is good or bad.
