P
PÿRÓ
Guest
Hey ..some of the guys in the post your work station pic thread, asked me about a worklog for my desk mod I did. So I thought I might as well put it in here ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Copyed from another forum I visit
Hi guys![Stick Out Tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As probably most of you know Im modding my desk and building my computer into it.
And was suggested that I make up a thread about it ..So here it is![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I wont go right into it and make this a work-log per say. More of a picture thread etc to show what I've done/doing.
But I will answer any questions, and if people have any ideas or would like to know something then by all means post![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ok ..
So most people have seen my desk in other threads etc.
Here it is here if you havent seen it
http://mywebsite.bigpond.com/pyro1970/systems/Pyros/1.JPG
An idea I have always had and wanted to do was build my computer into the desk.
Now Im sure there would be 101 ways to do this , but for me the best way to start was to use part of a case.
And so my Lian Li came under the knife ( or should I say dremel ).
http://img146.imageshack.us/img146/5082/14596526cs2.jpg
So basically I had to cut out the desk so the part of the case will sit down under it with the mb etc facing up.
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk1/?albumview=grid
After mounting the case into the desk. taking into account the thickenss of the desk top and also allowing the top plate (which comes later) to be routered down into the top.
Next was to cut out the hole in the desk etc.
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk2/?albumview=grid
At this point I had it all planed out on what I was going to do with the burners and the raptor x. And no idea on what I was going to do with the other hard drives or psu at this stage.
I had the idea of mounting the burners under the desk facing up pretty much like the case so they would end up flush with the top plate and pressing the button would have the cd tray eject up. Since they are not made to work like this, I would of had to mod the burner to hold the disk, like they can if they are mounted sideways. But in the end I was going to be cutting out to much wood and it would have weakened the top too much.
So I changed it to one burner mounted under the desk and when its ejected it lines up with a hole in the desk so you can access the burner. And the raptor x mounted under the desk so you can see the inside. ( I think in another thread that I showed one of these pics, some one thought that I cut away the top of the burner and you could see the disk spining away ...sorry but no can do
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk3/?albumview=grid
Ok.. So I still had a hole in the front of the case, which you will see in this pic
http://img146.imageshack.us/img146/2714/10ky5.jpg
I made up a plate at of aluminum and mounted two 12cm fans in the front to provide air flow to the mb etc.
Which was fine but I still had to make up some sort of cover for the front and find a place to mount some more hard drives.
Hmm after more time thinking about it, I ripped the front plate off and started again.
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk4/?albumview=grid
Should be able to work out from the pics what I have in mind![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Two 12cm fans with two hard drives mounted under the fans.
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk5/?albumview=grid
Mounting the fans etc into the plate.
And making up a cover out of mesh.
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk6/?albumview=grid
Basically thats pretty much it atm. Tomorrow I'll be cutting out the holes in the mesh for the hard drives.
Update 23/3
Ok today I pretty much got the front panel completed (paint last)
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk7/?albumview=grid
And also the hard drive holders with simple connect system. So I just need to pull them out or push them in from the front.
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk8/?albumview=grid
Update 13/7
Working on the top
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk9/?albumview=slideshow
And putting in the Psu
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk10/?albumview=slideshow
Update 2/8
Working on the top Part2, Raptor Lighting, etc
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk11/?albumview=slideshow
Pretty much just had to glue the windows in to finish the top plate off.
I also used some magnets drilled into the desk and glued to the plate to hold it down and to stop it from moving around.
As you can see with the raptor light system, I used some smd led strips stuck to the inside to light the inside of the raptor up.
The power switch I used a metal switch with a led to turn the system on, the blue led in the switch is the power led. The switch next to it opens and closes the dvd rom and the red led in the switch is the hdd led. I have also put the dvd led (dvd work light, also changed it to hi/b red) in the desk so it lights up the perspex ring.
Update 3/8
When This weekend I finished up the desk mod by installing the in desk usb powered hub.
http://img182.imageshack.us/img182/3515/10ub0.jpg
But I also decided to make up a headphone stand. But with the mic and output jacks the the ability to cut the sound to the headphones via a switch.
http://img98.imageshack.us/img98/5958/91129875tq9.jpg
And the finished pics![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk12/?albumview=slideshow
http://s303.photobucket.com/albums/nn143/Pyrooryp/Desk Mod/Desk12/Desk13/?albumview=slideshow
Hi guys
Ok ..
Update 23/3
Update 13/7
Working on the top
Update 2/8
Update 3/8
