Finally got my Opteron 165 and PC4000 ram as shown in my sig, so I threw them into my current machine (without needing to reinstall windows I might add, and so far so good) and gave a quick test run.
PWM IC was wavering between 36C after a semi-cold boot according to the bios, up to about 44C stock speeds in windows.
I then shut down and threw the HTT up to 250 but left everything else the same (other than dropping the HTT multi to 4 of course) and so far so good - I hope.
Just as a quick test, I'm going to prime both cores for a couple of hours at this speed and see what it looks like. But I notice that Smartguardian shows idle temp at 38C but PWM IC at 51C which is highlighted red. Chipset's fine at 45.
51C still all well and good, or dangerously high?
