VanGoghComplex
- Apr 5, 2016
I'm building a large outboard reservoir/pump combo for priming my relatively small loop. The best thing I can come up with on the cheap for the reservoir is a 4"dia piece of PVC pipe with a cap glued on one end (the "bottom").
I'm not sure what to use to glue it on. I don't want to use anything that might react with whatever fluid I use (probably just DI water and biocide, but I might change my mind.) I've got some PVC cement, the kind with the purple primer, left over from a plumbing protect. That stuff should be okay, right...? I mean, it's good for carrying drinking water, anyway. Anyone recommend something different?
