Puzzling Freezing in WinXP
s8n
I blew a cap on my old Gigabyte 8IRXP. A lot of dust had collected in the fins of my heatsink [Alpha w/ lots of pins]. I believe that attributed to me blowing the cap. The funny thing is that the system was *fine* but would randomly reboot/freeze every now and then. I attribute that to either the cap or the CPU overheating.
So I bought a 8IPE1000-G and an Antec True Power 430 [I had a 400W Antec before]. I assembled everything and after a little card swapping everything is fine. The only oddity is that every now and then my system will just freeze and I will have to reboot. I've run memtest and my ram passes just fine. I can run Prime on torture setting [or any setting] and it wll pass just fine. The highest my CPU temps get are around 31-32C.
CPU is a 1.6a@2.1 [currently at 1.6]
MB - Gigabyte 8IPE1000-G [rev 4]
RAM - 2x512 PC2100. Oddly enough I thought I had PC2700, but it turns out I don't. The only multiplier available to me is 2.6, so it's forcing me to run the bus at it's native 100mhz. Thus the non-existant CPU overclock ATM
VID - Nvidia 6600
Blah blah those are the major things.
I can play BF2 for hours on end, etc... and not get a freeze. But when I'm doing the most mudane tasks in XP it just freezes on me, forcing me to reboot. Everything is running at stock speeds ATM and 4 drives have plenty of cooling, CPU is fine... I figured maybe PS, but my old PS was just fine and this is a more updated version. More power on all rails, dual +12, etc.
So the system will pass all the synthetic tests, and will pass under real world torture. But when not put under any load I will get the freezing. One would think if I had faulty hardware the system would manifest itself when it was being stressed. The only other thing I can think of is maybe it's my copy of XP. I didn't re-format/re-install windows after the new motherboad installation. I thought possibly I could have damaged my CPU due to inadequate cooling [when the fins were blocked and I didn't know] but again... passes prime and gaming just fine.
I'm at a loss really. Tomorrow I'm probably going to try to rule out the drives by downloading the various manufacturer's HD utilities and testing them out. If they check out fine then the only other possibility I can think of... is my current Windows installation. If it's not either of those... what would you suggest?
One thought that passed through my head just now is the Dual 12V rails on the True Power 2.0 430 that I put in. Are the 12V sources on their own dedicated rails? Eg 4 pin n Sata on their own dedicated rails. I'm not utilizing any of the Sata connectors... could the load from the 4 Pin's be running on a single rail? While the other 17A rail is just completely un-utilized? I don't know what my old Antec 400w's power rating is [it's sitting under the coach in an unused box].... but could that possibly be the problem?
Again though... one would think the problem would manifest itself during high power usage [gaming, synthetic tests]... as opposed to simple tasks. My system freezes maybe 2 times every 24hrs, as opposed to before where I would leave my system on for weeks at a time between reboots.
If it's just randomly locking up like that, it sounds like a software issue. Have you looked through the Event Viewer to see if any strange Events have popped up?
Just in case you don't know how to access it:
Right-Click on "My Computer" and select "Manage"
Click on "Performance Logs and Alerts"
Select one of the three types of logs to see if any anomolous events have appeared that coincide with the times of the freezes.
Well I ended up solving my problem. Again it as random freezing. I could run bf2 for an hour, but sometimes it would freeze between map loads... other times it would be fine. I ended up taking off the HSF and putting a very very very thin layer of as5 on. That didn't help... so I ended up taking off the whole motherboard and noticed the alpha's retention system wasn't all the way tight on 2 corners. This caused a very small gap... but it was a gap none the less. I still don't know how the hell why my computer would freeze under 0 load in windows.... but would run a CPU intensive game or pass Prime for hours on end only to freeze on me a short period of time later. Regardless I dialed the clock back up and the CPU is happily overclocked again [I ended up buying some PC4000].
