Putting together my M-ITX system
rsantos97
So, I decided to downsize my main rig which is housed in an Obsidian 650D.
I will be keeping my 2600K, my ram and my 6670 and hard drives, but will be changing out everything else.
So far I plan on going with the SG05-450 and was undecided about the mobo. I don't know if I should go with a z77 or h77. For the z77 I was thinking of Asrock, for the h77 I was thinking about the Intel board. I haven't picked out cooling yet either. Right now I have an H80 with two GT AP-15's, but I doubt it will fit and won't even bother to try.
How many drives do you have, and are they 2.5" or 3.5"? The SG05 tops out at 1x 3.5", 1x 2.5" and 1x slim 5.25".
You might also want to consider Shuttle SZ77R5, SZ68R5, and SH67H3. They are slightly larger, but have much more room for drives.
Edit: Misread on my part.
For longevity, I'd caution against Shuttle; my SG45H7 died just after a year, and it seems to be a fairly consistent track record when you ask people about them in the past few years. (I don't remember if it was the motherboard or power supply.)
Originally, I was going to go with the SH63H3, then the SZ77R5 went on sale and was tempted to go with that, but then I saw that the Z77 m-itx boards were released and decided on that route. I owned a Shuttle XPC many years ago and have built two others for my sister and for a coworker, so I have experience with them. But I felt like the best bang for the buck was to go mini itx. The SZ77R5 would cost me $373 with shipping at Newegg. I could get the SG05-450 and DH77DF for $251 shipped at Amazon.
I'd go with Z77 based on chipset-native USB3.0 alone; in fact, I'm replacing my Z68 with a Z77 because my Zotac's add-on USB controller doesn't co-operate with my favourite mouse, among other things.
I believe the H77 has the same chipset-native USB3.0. The differences between the Z77 and H77 are that the H77 doesn't support overclocking through multiplier unlock and it doesn't support multi GPU like SLI or CrossFire, from the searching I have done.
Id definitely go z77. I went the h67 route with my 2500k and HATED not being able to overclock even a little bit. So i returned it and got a different board.
exactly.. although multi gpu would be out of the question with any itx board
Crap, thought it said H67 for some reason. :( :embarrassed:
I ordered the DH77DF since I probably won't be using many of the features that the Asrock has and I save $25. Plus I have 30 days to try it out and see if I like it. I am planning of keeping my DVD Burner and using a sata to esata cable to use it externally when ever I need it. I was going to get a slot loading slim drive but all slim drives are slower than the 5.25 drives, and I hate waiting when I am burning something or ripping something.
I get the sense that you didn't consider the Asrock H77 board - it's $25 less than the DH77DF: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157311
I saw it but I liked the audio (898 vs 892) and lan (intel vs realtek) chips better on the intel board.
I just ordered an esatap to sata cable to hook up my DVD burner externally. I was just going to get a slot load drive because I think they are fun to use but the opening on the SG05 is made bigger to accommodate tray drives, so it doesn't look perfect. That plus the slower speed and a little bit higher price makes it a no go.
