Ok so here are the components I have so far.
Mobo : Abit NF7
RAM:?
Proc: Mobile Athlon XP 2400+
HSF: Thermalright SLK-947U w/ Enermax adjustable 92mm fan
Can any1 tell me if this HSF setup is good enough to get a decent OC out of this proc. I want to run it as quiet as the Zalman 7000Alcu that I have on my P4 computer... I picked up the slk-947U for $20 form SVC so I think its a good deal no? I hope its a good one...
Could you guys recommend some RAM though. I dont care if its dual channell or not. I just need one stick of 512, that will be able to handle the OC from the processor. I prefer to spend less than $100 if possible. Thanks guys.
Mobo : Abit NF7
RAM:?
