Thanks again GuruYou should start charging !!!
You don't need a website to walk you through building a computer.
If you bought a mobo from a decent brand, you should have a manual that explains the options. If not, if there's an option you aren't sure of, ask here or google it. Much of the options are common sense, such as the floppy drive mentioned above. If you don't have one, disable it. if you're using an add-in sound card, disable onboard sound, etc.
