best [486];1033236535 said:I think the 2.5 inch SATA power plug is smaller, look on newegg for an adapter. It would come in a kit that includes the rails, though you could use double sided foam tape to mount it almost anywhere.
I am using a shuttle with a 2.5 drive and the sata power is the same.
@best [486]
how stable is the hdd when you used double sided tape? a lot of vibration?
best [486];1033247444 said:But then what's the point of using a 2.5" HDD?
3.5 ones are so much cheaper, faster, have more storage, etc...
