Pushing the FSB
Arnge
i have 2*1 GB superTalant rams with FSB 667
i have a P36 DS3R Gigabyte mobo.
and on the bios setting i have it run on turbo mode.
which increases the Memory and Cpu FSB .
the memory have gone from 333.3 to 386.
is that safe.
i made no voltage increase or anything.
Temperature and voltage are the main killers of components, so as long as those two are in check, the extra MHz usually isn't an issue.
With that low frequency, I highly doubt temperature is an issue and since you didn't manually adjust voltages...those are stock as well.
Therefore, I'd go with, no...I wouldn't worry about it.
How do i check the temp.
it have heat spreaders so it is hot to touch even on stock MHZ.
