I've got a P4 3.06 SL6S5 Malay. That is a C1 stepping, 130 Micron, HT Northwood. 533 FSB.
Running with stock cooling on a ASUS P4G8X Delux. 1 GIG of Kingston HyperX PC3000 running Dual Channel. So far I've managed 3.357 GHz @ 1.600v (as set in bios) This is powered by a thermaltake silent pure power 480W. I'm using the P4 12volt connection vice the 4 pin molex for extra juice to the board (does this make any difference?). How far can you push this chip (CPU Database @ overclockers.com is down). How far can I push the voltage on a northwood?
So far it is stable at this setup.
Case is cooled by 2 120mm Sunon fans @ 7v. Case temp = room temp no matter what the load is.
Motherboard monitor shows the voltage on the strong side of 1.600... like 1.680
Idle 38C, loaded 57C (Max rating from intel 68C)
Running Prime95 torture test for max load and heat, combined with ATITool pushing my 9600 Pro (lite) which is also overclocked 476/253. No instablilities.
Only real complaints are I cannot seem to reach 3.4GHz stable and no matter what the BIOS settings (rev 1006) no manual adjustment of CAS timings has any effect. CAS timings seem to stay the same @ those reported by SPD even tho the RAM is waaay over the PC2100 (I think it is) required by 533
